LabVIEW Real-Time Idea Exchange
swenp
Native XML support on Real-Time targets
Status: New
Wouldn't it be nice to have a native LabVIEW XML parser available on real-time targets? Storing your config data in XML rather than in Config-ini files is more flexible, techniques like XMLRPC would be easier to implement etc.
Yes I  know about the third party EasyXML library, but I don't want to spend extra money as we are already paying for LabVIEW 😉
4 Comments
jkurtw
NI Employee (retired)
Will this work for you?
Reference Library for Converting Between LabVIEW and XML Data (GXML)
http://zone.ni.com/devzone/cda/epd/p/id/6330
swenp
Member
Thanks for the link, but this implementation eleminates a big benefit of XML: The flexibility. Using the GXML library I will be bound to the type of cluster the data was saved when trying to read it. Otherwise the Variant to Data will fail if I added or edited some cluster elements in the time between saving and loading the data. Thats why I think a real XML parser would be great on RT.
MattWhitlock
Member
I agree that it would be pretty useful. I've done a decent amount of XML parsing on cRIO, but the CPU/Memory manager is pretty slow when parsing a ton of text. On PXI though, a native and flexible (real) XML parser seems like a no-brainer.
S.Minami
I agree completely.
In Japan, we created automatic update application under RTOS on cRIO.
Then, we couldn't use a native LabVIEW XML parser.
So, we selected LabVIEW schema.
In the near future, we need the native LabVIEW XML parser on Real-Time Target.
Because we want to connect between Web API and cRIO.
And, we can get the correct Japanese character because LabVIEW XML parser supports Encoding: "UTF-8".
