LabVIEW Real-Time Idea Exchange
About LabVIEW Real-Time Idea Exchange
Have a LabVIEW Real-Time Idea?
  1. Does your idea apply to LabVIEW in general? Get the best feedback by posting it on the original LabVIEW Idea Exchange.
  2. Browse by label or search in the LabVIEW Real-Time Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  3. If your idea has not been submitted click New Idea to submit a product idea to the LabVIEW Real-Time Idea Exchange. Be sure to submit a separate post for each idea.
  4. Watch as the community gives your idea kudos and adds their input.
  5. As NI R&D considers the idea, they will change the idea status.
  6. Give kudos to other ideas that you would like to see in a future version of LabVIEW Real-Time!
Top Kudoed Authors
User Kudos Count
1
1
1
Make the RT Console Easier to View from MAX
Currently, you can view the console from MAX, but if you don't know what buttons to press... lets just say it's in there somewhere. My idea is to make it more accessible, such as a right mouse button feature off the RT Target.
4 Comments
Member JCC_(SK)
Kudo +1
This should be implemented to cRIO as well.
Member Deborah_B
The ability to view the console is available when you use the Network Browser to connect to your target, or just type in the IP Address into your internet browser.
Deborah Y.
LabVIEW Real-Time Product Manager
Active Participant Texas_Diaz
This unfortunately isn't "valid" on a Linux-based cRIO controller, like the cRIO-9068. Unless, of course, it provided a direct link to the actual Linux console (by opening putty or some similar tool). -Danny
Member Deborah_B
Status changed to: Completed
I'm going to mark this as completed for the Network Browser use case and then the NI Linux Real-Time target case is captured in this newer post: http://forums.ni.com/t5/LabVIEW-Real-Time-Idea-Exchange/Add-console-to-Linux-based-cRIO/idi-p/287113...
Best Regards,
Deborah Y.
