LabVIEW Real-Time Idea Exchange
About LabVIEW Real-Time Idea Exchange
Have a LabVIEW Real-Time Idea?
  1. Does your idea apply to LabVIEW in general? Get the best feedback by posting it on the original LabVIEW Idea Exchange.
  2. Browse by label or search in the LabVIEW Real-Time Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  3. If your idea has not been submitted click New Idea to submit a product idea to the LabVIEW Real-Time Idea Exchange. Be sure to submit a separate post for each idea.
  4. Watch as the community gives your idea kudos and adds their input.
  5. As NI R&D considers the idea, they will change the idea status.
  6. Give kudos to other ideas that you would like to see in a future version of LabVIEW Real-Time!
Top Kudoed Authors
User Kudos Count
1
1
1
Expanding the data processing functionality of the SCAN Engine
Many measurement and process control application run at relatively slow rates (<100Hz). Using SCAN Engine on the CompacRIO for data acquisition is ideal for these applications because you don't need to program the FPGA and all the measurement and control logic can be implemented on the Real-Time controller.
In many cases you want to process your data before you analize it. Currently you only have the ability to get the raw measurement data from the AI modules, so you need to add the data processing code to your existing LabVIEW program. It would be helpful if the SCAN engine could offload some of the data processing (ex. lowpass filter or sample average) to the FPGA and provide the user with already processed data. For example, this functionality can be added to the module configuration page:
1 Comment
Member MarkCG
I almost always create a hybrid-mode FPGA bitfile when I need data from analog input card like the 9205 or 9215 and do a rolling  average on the FPGA . I suppose you could do a timed loop synchrozied to scan engine and do it there, but you would need to run your scan engine at a faily high speed (100 Hz or more) , which I do not like to do. Good idea.
