LabVIEW Real-Time Idea Exchange
About LabVIEW Real-Time Idea Exchange
Have a LabVIEW Real-Time Idea?
  1. Does your idea apply to LabVIEW in general? Get the best feedback by posting it on the original LabVIEW Idea Exchange.
  2. Browse by label or search in the LabVIEW Real-Time Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  3. If your idea has not been submitted click New Idea to submit a product idea to the LabVIEW Real-Time Idea Exchange. Be sure to submit a separate post for each idea.
  4. Watch as the community gives your idea kudos and adds their input.
  5. As NI R&D considers the idea, they will change the idea status.
  6. Give kudos to other ideas that you would like to see in a future version of LabVIEW Real-Time!
Top Kudoed Authors
User Kudos Count
1
1
1
Easier NI-MAX access to CAN-Modules NI-9862 in cRIO
Currently viewing, testing or configuring NI-9862 Modules in a cRIO using NI-MAX needs a lot of effort. It requires:
- Installation of the complete Labview Realtime and FPGA development suite on the connected PC
- Setting up a Labview project including the NI-9862 Modules and an empty FPGA VI
- Compiling the emty FPGA VI to a FPGA bitmap file
- Starting the FPGA VI
Without these steps the NI-9862 Modules are invisible in NI-MAX
Proposed improvement:
- NI-MAX should include a default FPGA bitmap file that includes the communication with NI-9862 modules
- When the user connects to the cRIO with NI-MAX, the current cRIO configuation should be automatically saved to a backup and the default bitmap file should be activated
- When the user disconnects, the backup should be restored
Advantage:
- viewing, testing or configuring NI-9862 Modules in a cRIO could be possible just by starting the NI-MAX and connecting to the cRIO, as simple as with any standard I/O modules.
1 Comment
Active Participant JefeL
We aware of this pain point for our cusotmers are are working to improve the overall experience. Technical limitations have prevented us from including native support for NI-MAX functinoality on our older cRIO devices. We have been able to improve the experience with cRIOs that run Linux-RT such as the 903x series which include native support by default. In a cRIO-903x, a XNET C-Series device can be detected and updated in MAX without the need to compile a bitfile etc.
