Would you be dynamically creating and destroying network variables during runtime on your RT target? Or is it just for initial setup up and system replication?
In my case I need to update the software on my cRIOs via cell modem. I'm able to update the executable, but would like to do the same for shared variables.
Why isn't it possible? Whatever is happening when the Host PC connects to the target, should be able to be done within the cRIO itself. NI, where is the information about shared variables stored (doesn't look like in a file...)?
I update my remote cRIO by detecting a USB is inserted, then copy over the rtexe and reboot. I was stung recently because i had included new variables and there is no way to deploy the variables directly from the target. I cant see a reason why this would be difficult, and it does seem like an oversight. My often cRIO systems are never connected to a host PC.
It does not help that the Deploy Library node which works in windows does not give a broken arrow when placed on a real time VI, it just returns a runtime error.
