As far as I know, a thumb-drive or hdd that you connect to a cRIO USB port has to be formated using FAT. It would be very handy if NI would support attaching drives formated with the Reliance NITRO file-format. This could in some cases also lessen the pain of being stuck with Reliance (old version) on the cRIO main drive. It would also ensure deterministic file IO on the USB drives in case of power failure, un-expected device disconnection etc.
Thanks for reading and hope for your vote!
QFang
Hi QFang,
We could use some more information on how you would use this feature and what it would add to your current application. What problems have you had with the current Reliance implementation on the cRIO internal disk? How is the removable storage used in your application and does it ever need to be mounted to a Windows PC?
Thanks!
Tanya
LabVIEW Platform Product Support Engineer
Hi Tanya,
The current problems I have with Reliance on the cRIO is a little besides the point for this idea, but they include: slow performance if any folder has 100 files or more, performance loss for files over ~50kB in size.
The removable storage the way it currently is used is only for log file transfer from non-networked cRIO's back to corporate Windows machines where labVIEW code will import the contents of the stick to a database. The benefit of Reliance NITRO in this case is limited, but if we assume a USB drive could be mounted to both windows and cRIO with a Reliance NITRO file system, its use could be expanded to direct logging of files to the thumbdrive (instead of copying off of the cRIO drive), configuration management etc. because the risk of data loss or corruption in the case of an unexpected power loss or dismount event would be next to nil.
Hi Tanya !!
I really support QFang's idea.
I have the same problems with USB sticks (FAT32-formatted), as the application I wrote (for a cRIO-9076 situated on a rotating part of a wind turbine), wirelessly transmits my waveforms to a PC, but when the transmission breaks, then the waveforms are stored on the USB. In that case, QFang describes perfectly the issues I am facing...
Dimitri
You must be a registered user to add a comment here. If you've already registered, please log in. If you haven't registered yet, please register and log in.
My Profile | Privacy |
Legal |
Contact NI
© 2011 National Instruments Corporation. All rights reserved. | E-Mail this Page
E-Mail this Page
