LabVIEW Real-Time Idea Exchange
About LabVIEW Real-Time Idea Exchange
Have a LabVIEW Real-Time Idea?
  1. Does your idea apply to LabVIEW in general? Get the best feedback by posting it on the original LabVIEW Idea Exchange.
  2. Browse by label or search in the LabVIEW Real-Time Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  3. If your idea has not been submitted click New Idea to submit a product idea to the LabVIEW Real-Time Idea Exchange. Be sure to submit a separate post for each idea.
  4. Watch as the community gives your idea kudos and adds their input.
  5. As NI R&D considers the idea, they will change the idea status.
  6. Give kudos to other ideas that you would like to see in a future version of LabVIEW Real-Time!
Allow Shared Variable Engine on RT target to act as OPC-UA server
The SVE on a windows based platform acts as a OPC-DA server. Due to the requirements for DCOM, this is not possible on real-time target. However, as OPC-UA is gaining traction, I would find it very useful to have the SVE act as an OPC-UA server for integration with 3rd party systems (SCADA, IIoT).
I know that there is the OPC-UA API palette, however, this takes more time to setup than creating a shared variable (i.e. a tag) and moving on with the application development. If update rates are slow enough (500-1000ms), I have found the shared variable to be more than adequate for my applications (500-800 NSVs), so I'm not looking for granular control over how I send data out of the cRIO system. Ease of use is my primary concern.
