The RAD tool is not a perfect fit for all cRIO deployments. If you are unable to use the RAD utility to deploy a new version of drivers to the cRIO the process to get the Network Variable Engine onto the cRIO goes something like this: Install LabVIEW and LabVIEW Real-Time, install NI CompactRIO drivers, install NVE and other driver software to the cRIO and then uninstall the LabVIEW components from the host PC. This assumes that an executable will be installed to the host computer as the UI to the cRIO. Seems like a lot of work for something most people would be using on the majority of cRIO deployments and might assume is a part of the CompactRIO drivers.
At the very least it would be great if the documentation found on the website were explicit as to what software needs to be installed for each of the install options available to install on to the cRIO.
