LabVIEW Real-Time Idea Exchange
About LabVIEW Real-Time Idea Exchange
Have a LabVIEW Real-Time Idea?
  1. Does your idea apply to LabVIEW in general? Get the best feedback by posting it on the original LabVIEW Idea Exchange.
  2. Browse by label or search in the LabVIEW Real-Time Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  3. If your idea has not been submitted click New Idea to submit a product idea to the LabVIEW Real-Time Idea Exchange. Be sure to submit a separate post for each idea.
  4. Watch as the community gives your idea kudos and adds their input.
  5. As NI R&D considers the idea, they will change the idea status.
  6. Give kudos to other ideas that you would like to see in a future version of LabVIEW Real-Time!
Add a version number to RT EXE files
When working in the Windows development environment the application builder has the ability to implement a version number for the built executable. Additionally LabVIEW has the ability to querry this version number through a property node. I would like to see this feature carried over to RT systems as well. It would be very helpful in determining what particular build of the startup.rtexe file is running on the target.
6 Comments
Active Participant Deborah_B
Status changed to: Completed
Versioning is an option when you build a component definition file (.cdf), which includes an rtexe and its dependencies. This is an option when you build your rtexe in the Real-Time Application Properties dialog box>>Component Definition. Creating this file allows you to deploy the real-time application using MAX or programmatically with the LabVIEW System Configuration API. You can choose to manually specify the version number when you build the application or LabVIEW will Auto increment the version number each time you build. The first build would be 1.0.0.0 and the next time you build it, it may be 1.0.0.1...etc.
Member MHn
I would not declare this point as completed.
.rtexe versions and cdf-versions are not the same.
If I deploy an application direct from the project, the cdf will not be touched.
I think, gsussman's intention was the same as mine, to increment the version of an real-time application (.rtexe) each time it is built.
Only with that I can be sure about the correct version of the .rtexe.
From the cdf-version only, I can not determine if the application (.rtexe) had been updated meanwhile.
Status changed to: In Development
Member James@Work
Obviously not "In Development" since 2015 Smiley Wink
However, versioning of RT Targets can be tracked easily when using images.
The image name/version is available from MAX and programmatically.
Member MHn
James,
I agree, image names / version and component definitions are possible solutions to handle a version on RT targets.
Anyways, in both ways you can exchange the .rtexe-File by deploying or FTP-transfer with a newer version without getting rid of it.
best regards,
Martin
Active Participant JoshuaP
You don't know that.
