LabVIEW Project Providers
ProjectItem Sorting?
When "Arrange By" is applied to a ProjectItem that contains other ProjectItems -- for example, the "My Computer" node or a Virtual Folder -- can the re-shuffling of ProjectItems be intercepted by one of the Project Provider callbacks? Ideally, is an event or callback thrown after the re-shuffling has occured, so that the new order can be post-processed?
(2,519 Views)
In other news... I just found out you can mark a discussion as a question and dole out points to good answers! If only i could retroactively do this for all the good answers on this forum!!!
(2,490 Views)
Unfortunately, I couldn't find any events in the provider framework that are being called after "arrange by" is executed. It looks like all that code is implemented in LabVIEW's core code.
David, when you get a chance please check with someone at NI who can confirm this (after NI week ofcourse:))
If only there was something similar for the great questions that come up here too:)
-Sumedha
Sumedha Ganjoo | LabVIEW R&D
(2,490 Views)
