LabVIEW Project Providers
LV crash caused by mxLvGetFilePathBatch.vi
Hi Eric,
I started tinkering with this today and was able to reproduce your original crash.  However I'm NOT able to reproduce the crash with the the mxLvGetFilePath.vi in a for loop.  Can you provide a test case that demonstrates this second crash?  Does this happen in the normal LabVIEW context, or only when in a project provide context?  Finally, can you briefly describe what your end goal is with this VI and what it's purpose is in your provider?  This will help me to find a suitable workaround, since even if this CAR is fixed, I'm sure you'll want it working correctly for older versions of LabVIEW.
David
Message 11 of 11
(689 Views)
