LabVIEW MathScript RT Module
integration function
I am a user of LabVIEW 8.0.
I want to integrate a function(x^2) of x from 0 to 1.
Is it possible by mathscript?
Please refer to the attatched file.
(8,627 Views)
In your attached file, you are attempting to perform an integration with a symbolic variable.  Unfortunately, MathScript does not support symbolic mathematics at this time.  MathScript does support the trapz numerical integration function.  You will first need to create a vector of evaluations of your function of interest.  We are considering adding additional integration functions in a future release of LabVIEW.
Grant M.
Staff Software Engineer | LabVIEW Math & Signal Processing | National Instruments
(8,611 Views)
>>help trapz
trapz (MathScript Function)
Member of the vector class.
Hi Grant & zolaman
Am I missing something here? Have a look MatScript trapz help below
Syntax
c = trapz(y)
c = trapz(x, y)
Description
Computes numerical integration using the trapezoidal method.
Inputs
x - Specifies the x-values of the function that you want to integrate. x is a vector.
y - Specifies the y-values of the function that you want to integrate. y is a vector or matrix of the same size as x. If y is a matrix, c returns the integrals of all columns of y.
Outputs
c - Returns the numerical integration of y. c is a scalar or vector.
Examples
Y = [0, 1, 2, 3, 4]
C = trapz(Y)
Related Topics
cumsum
sum
(8,607 Views)
Hello Blue_Math,
Well, as I mentioned, MathScript does support the trapz function.  However, this is a numerical integration function and it looks like zolaman wanted to perform a symbolic integration.  For the particular function mentioned (x^2), the numerical approximation will be reasonably accurate.  We simply need to evaluate the function over the points of interest.  For example,
x = linspace(0, 1);
y = x.^2;
A = trapz(x, y)
Grant M.
(8,589 Views)
