NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
sky10
imread (fread_image) and .m file in mathsript node
Hello. I got problems.
In Matlab, imread(filename) returns M-by-N-by-3 array if the file contains a truecolor image.
The problem is to give M-by-N array when I used fread_image in labview mathscript.
How can I get M-by-N-by-3 array in labview mathscript?
One more problem is about the mathscript node.
Can I call the defined .m file functions in mathscript node?
For example, just image that I've already defined some .m files in LabView data directory.
Then, is it possible to call these functions in mathscript node?
I know that it works in Labview mathscript.
Now I want to run these fuctions with mathscript node in VI.
Please help me.
Active Participant
ttrr
回复: imread (fread_image) and .m file in mathsript node
MathScript currently does not support 3D array. Then, fread_image is not able to return M-by-N-by-3 array.
Yes, you can call user defined function in MathScript Node. Just make sure that the function is in MathScript Search Path.
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
