LabVIEW MathScript RT Module
how to feed a cluster into the mathscript?
Hi all,
  I am trying to feed a cluster into the mathscript. I found that if the name of the cluster element does not have any space or special characters, it works pretty well. But it doesn't run if the name of the cluster elements have any special characters. Is it how Mathscript designed? Any workaround here?
(6,962 Views)
Accepted by topic author dragondriver
Hey dragondiver,
Hope you're doing well today. This document overviews the intended use and behavior of data types with MathScript.
Passing Data in and out of the MathScript Node (MathScript RT Module)
http://zone.ni.com/reference/en-XX/help/373123C-01/lvtextmathmain/ms_passing_data_lv_mathscript/
So, to answer your question more specifically, the rule for naming of elements within a cluster passed into the Node is,
"You must label individual elements of the cluster. Labels must start with an alphabetic character and can contain only alphanumeric characters and underscores without any spaces."
This should account for the behavior you're seeing with your code!
Tim A.
(6,929 Views)
(6,921 Views)
