LabVIEW MathScript RT Module
global - MathScript Node Failed To Compile Error
I have Labview 2009 SP1 with Mathscript Module.
While using 'global' command, I've encountered "MathScript Node Failed To Compile Error" from the first time I tried it.
In Mathscript window:
'Error in line 0:  An internal error occurred while processing this MathScript. Contact National Instruments with the MathScript you used.'
is produced for any simple 'global a' (or any other variable name used).
(8,347 Views)
I've also made all the steps and it didn't help...
Bad Instantiations.exe does not detect error, but 'global' command is still unusable.
(8,342 Views)
Opps, one step you missed in the error code: Contact National Instruments with the Mathscript you used.
Go ahead and attach some example code that is throwing this error and I'll see if I can reproduce it on this end. There were a bunch of updates to the Mathscript Node in the F3 Patch so make sure that or LabVIEW 2009 SP1 is installed.
Also, are you seeing this on any other computers?
Look forward to hearing back!
Logan H
(8,318 Views)
1. trivial "global" command didn't work (all others did work).
2. It was new installation.
I've installed SP1 first, and then Mathscript.
Do you mean I need to reinstall SP1 (repair installation?) ?
(8,312 Views)
