LabVIEW MathScript RT Module
convert MathScript node to regular wired diagram
I wrote a program last year in LabView 8.6, with some MathScript codes in it.  But this year, after I upgraded LabView to 2009 Full Development System, I am not able to run this program anymore because I didn't purchase the MathScript Module.  And what even worse is, when I wrote the program, I shrinked the script node frame too much in order to save some room, but now I cannot even drag the frame bigger.  So now everything is hidden inside the script frame and I cannot see what's inside.  Is there anyway that I can find out what's inside the script node so I can translate them to regular wired diagram?  Thank you in advance.
Message Edited by Support on 03-04-2010 02:25 PM
(7,555 Views)
Unfortunately there's no way to see your code without MathScript being installed. This seems like an overzealous restriction, so I have filed a bug report (ID 211321) to allow resizing and exporting text in a future version.
In the meantime, I can think of two options. You could install the MathScript RT Module in Evaluation mode. This will let you try it out for 30 days for free. Or I'd be happy to copy the text from your nodes and post it on the forums. If you'd like me to do that, just let me know which VIs to look at in your ZIP file.
jattas
LabVIEW MathScript R&D
(7,548 Views)
jattas,
I've already run out of my evaluation and didn't realize the problem when it was working.  Anyway, I think I need your help to copy the text from the mathscript nodes.  But instead of posting them in this forum, can you send them to my email address lchen@abound.com?  Because they contain my company's proprietary programs, so I'm afraid we cannot let it go public.
In the ZIP file, "calibrate.vi" and "LaserThickness_main.vi" are the two files that have mathscripts in them.  Thank you very much.
Lei
(7,523 Views)
Hello Lei,
I just sent the code to you in an email. Please let me know if you don't receive it.
jattas
(7,509 Views)
