Created a VI that uses a MathScript Node. Need to change code in said MathScript Node. I cannot do this because I am not allowed to edit the MathScript Node. Why is this a feature of the MathScript Node? Am I missing some understanding of the functionality of the MathScript Node? I cannot even add or delete inputs or outputs to the Node. Write clicking does nothing. Double left clicking only highlighs the entire Node to be moved around the Block Diagram. That is the only thing I am allowed to do to the MathScript Node; move it around the Block Diagram.
