LabVIEW MathScript RT Module
Probe of the Mathscript
I used 'Probe of the Mathscript' but I can't now
How can i use it again ??
'Probe screen' does not seen after probe menu click on the math script window.
After that 'searching probe menu' can be seen, but 'probe window' can not be seen.
So i did uninstall all installed labview programs, and reinstall 'labview 2009-kor(32bit) , RT-module and fatch3(32bit)' on window vista 64
but states are same.
What can i do ?
(7,460 Views)
Is the question related the following ?
152620
Return
MathScript probe does not work on VI running on RT
Workaround: N/A
Reported Version: 2009  Resolved Version: N/A  Added: 08/03/2009
(7,422 Views)
If your VI is running on an RT target, then yes that would explain why the Probe option does not show up in your menu.
(7,406 Views)
Now I can understand my labview situations.
Mathscript probe was disappeared after plug NI USB 6211.
Mathscript probe was not appeared but RT module was not present.  I guess a certain flag was turn on.
Installing and removing LV2009kor+ fetch3,   LV2009eng32 +fetch3 and  LV2009eng64 +fetch3  was not not worked.
Now mathscript probe show up  after installing LV2009eng32sp1 and RT-module.
It takes very much time,,,,,
(7,366 Views)
