06-15-2010 03:35 PM
Okay, so I have a function defined in a file that essentially does an inverse Abel transform sort of thing on a really big matrix that it takes as an argument. The m-file for that function is attached. It works on MATLAB, uses only standard syntax AFAIK, and also works on Octave. Yet when I call it from the Mathscript Window, it takes a while to compile and gives this error:
Error in function augie_image_processing_function at line 1: LabVIEW cannot compile the current MathScript. Contact National Instruments with the MathScript you used.
Anybody willing to point me in the right direction? Thanks in advance!
-PA
06-15-2010 04:57 PM
