05-25-2013 06:17 PM
Hi All,
I have recently installed LabVIEW 2012 in my PC with Windows 7. However, Mathscript is not working at all. It says "An internal error has occurred in the MathScript RT Module. Restart LabVIEW and try again. If the error persists, reinstall the MathScript RT Module." I did that but still does not work. It further says that Mathscript is missing or not installed" but I have installed it. What could the problem be, please?
Solved! Go to Solution.
05-28-2013 01:25 PM
Are you installing the module with an installer you downloaded or from disk? You can download the software on this page:
https://lumen.ni.com/nicif/us/evaltlktsigproc/content.xhtml
You will need to unzip and install for your current LabVIEW version. Have you also activated this module? If you check under LabVIEW 2012 and then Modules in NI License Manager (Start>>All Programs>>National Instruments>>NI License Manager), do you see the MathScript RT Module listed and colored green? It should also say "Activated for this computer" on the right panel when selected.
If the module does show as activated, can you post more info on the behavior you are seeing? When exactly are you getting the error mentioned? Does it show up when opening LabVIEW, dropping a MathScript Node, executing code with a MathScript node in it, etc?
05-28-2013 01:59 PM
Also, are you using 32-bit or 64-bit LabVIEW?
05-28-2013 04:34 PM
It comes when I open a Labview program that uses mathscript.
05-29-2013 12:04 PM
Were you able to check the installation and activation in NI License Manager? It should say Activated for this Computer and have a green square like this:
05-29-2013 01:21 PM
I am using 32 bit LabVIEW.
05-29-2013 01:43 PM
I don't see the mathscript activated in the list.
05-30-2013 09:16 AM
Is MathScript Node listed in License Manager at all or is it missing?
If it is in the list, what color is the box and what is its status? You need to activate MathScript with your serial number. If this does not work, verify that your serial number includes a license for MathScript by contacting your NI Account Rep at (888) 280-7645.
If MathScript is not in the list, it is not installed for LabVIEW 2012. You can find the installer at the link in my first post.
06-07-2013 04:13 PM
Hi guys, excuse me but, I have a little problem, I use Labview 2012 64 bit, I downloaded MathScriptRT for this pack, but, when I want to installed, send me a message that I have to installed Labview 32 bit, why happend that? Could you help me? please
06-07-2013 04:37 PM
AFAIK, Mathscript is 32bit. Is there any reason you are using 64bit LabVIEW?
