LabVIEW MathScript RT Module
Irrelevant Mathscript error -20033
Hi there,
I am trying to make some code work with MathScript RT in LabView 2012, but I keep getting an error -20033 (see screenshot below) for an irrelevant line of code.
The line MathScript complains about (line 45) is the following:
percentLast = floor(max(levelPercent));
This error does not make any sense for that line (levelPercent is a 1D array), and no line above or below corresponds to that error either.
If I comment out the offending line, I get the same error for another completely unrelated line.
Also note that the very same code works well with MATLAB.
Is there a known bug in MathScript that could create this behavior? If yes, is there a way to work around it?
Thanks in advance for your help.
Olivier H.
(6,049 Views)
The error code should be returned from filter design functions. Do you call any filter design functions before line 45?
(6,032 Views)
Actually, I could trace this error to a call to resample() at another unrelated location (and different .m file) in the code. I found it by basically commenting out one line at a time until the error disappeared. It looks like error reporting needs some work in Mathscript.
Olivier
(6,013 Views)
Is it possible for you to post the code to call resample()? resample() might throw this error if it fails to design a filter.
(6,007 Views)
