LabVIEW MathScript RT Module
How to use "lsqcurvefit" in labview 8.6
I learn to use 'lsqcurvefit'  function by the example in labview 8.6 help,
first, define myfum.m as follows:
function [F, df] = myfun(a, xdata)
F = a(1)*xdata.^2 + a(2)*cos(xdata);
df = zeros(0, 0);
then I use a mathscript node in block diagram,define as follows:
a = [2, 1.5];
x = 0:1:19;
noise = randn(size(x)) / 5;
y = a(1)*x.^2 + a(2)*cos(x) + noise;
[x, normres, resid] = lsqcurvefit('myfun', [10, 10], x, y);
however, when I run the program,labview always tell me:
Error -90111 occurred at Error in function lsqcurvefit line 5.The function you
specified as an argument is invalid.
Who tell me why?thanks.
(6,612 Views)
Which version of LabVIEW do you use? I try your code in both LabVIEW 8.6 and 2009. Everything works well.
(6,607 Views)
thanks, the problem is solved, the error due to the path of myfun.m.My labview version is 8.6
(6,605 Views)
