05-22-2012 05:23 AM
Dear sir/madam,
I having a binary coded file, and Matlab code also, but i am not able to open that file , so I want to open and run that file according Matlab code. here is image what i want to do, and also attached here input file and matlab code.
Solved! Go to Solution.
05-22-2012 08:27 PM
Your script reads data from .dat file and formats it into 3D array. Unfortunately, MathScript currently can not handle 3D array.
By the way, you can use the following code to read the data in LabVIEW.
05-29-2012 05:12 AM
Dear sir,
Thanks for your reply,, I have tried using the program suggested by you but not working,.
Please suggest any other option, here i have attached input file.
05-29-2012 10:15 AM
You need to be more specific than "not working".
05-29-2012 08:44 PM
I do not see any problem to read the data from new attached input file. The following figure shows the data in Waveform Graph.
05-30-2012 02:09 AM
Dear sir,
Thanks for reply,
Please send me the output file, which u got from the programme. I want to check wher is my mistake, and also programme whcih u have used,
Thanks and regards
Kunvar yadav
05-30-2012 02:15 AM
Attached is the LabVIEW 2011 VI to read the file. The data read from the file is saved as default value.
05-30-2012 04:38 AM
Dear Sir,
Thanks for sending Labview VI. But i have labview 2010 thatshows error please send the vi in Labview 2010.
05-30-2012 07:05 AM
Here is the LabVIEW 2010 VI. I do not see any problems. Try it and let me know whether it works.
