LabVIEW MathScript RT Module
Help with mean filtering and noise reduction using Mathscript
Hello, I have this:
The idea of mean filtering is simply to replace each value in a signal with the mean (average) value of its neighbors. A mean filter is widely used for noise reduction.
Start by adding some random noise to a signal (use the file echo_1.wav or any other speech data file). Then, use mean filtering to reduce the introduced noise. More specifically, take the following steps:
  1. Normalize the signal values in the range [0 1].
  2. Add random noise to the signal by using the function randn. Set the noise level as a control.
  3. Convolve the noise-added signal with a mean filter. This filter can be designed by taking an odd number of ones and dividing by the size. For example, a 1× size mean filter is given by [1/3 1/3 1/3] and a 1×5size mean filter by [1/5 1/5 1/5 1/5 1/5]. Set the size of the mean filter as an odd number control (3, 5 or 7, for example).
(4,451 Views)
Hi master 45,
What have you done so far? Any specific question about your application?
(4,399 Views)
