LabVIEW MathScript RT Module
Getting Mathscript formula to output audio question sal22
Greetings all
I'm trying to use a mathscript formula to produce an audio wave form however all I get back is a blank line.
I've attached my vi to show you what happens
tia sal2
(7,149 Views)
The second line of your mathscript is actually performing the waveform generation for you.  If you change the output type of b to a 1D array of double, you can wire this directly to the output sound VI.  Choosing to have b output as a string causes MathScript to convert the first element of the array (0, in this case) to a character.  The ASCII character for 0 is a null character.  Consequently, the Formula Waveform VI doesn't have anything to work with.
Grant M.
Staff Software Engineer | LabVIEW Math & Signal Processing | National Instruments
(7,145 Views)
