NI Home
Cart Cart | Help
You are here:
Reply
Member
us09
Re: FFT performance
You can find the TSA Welch.vi under
Signal Processing | Time Series Analysis  | Correlation and Spectral Analysis.
It comes with the "Full Developers Suite".
Knight of NI
altenbach
Re: FFT performance
Well, I have LabVIEW professional and don't have it.
I believe these tools are part of the NI LabVIEW Advanced Signal Processing Toolkit which costs extra. :smileysad:
LabVIEW Champion . Oh, by the way, I work for peanutsKudos .
Knight of NI
altenbach
Re: FFT performance
OK, you are mixing terms here, don't use "Full" in this context. :smileywink:
There is "Base", "Full", "Professional", and "NI Developer Suite". You must have the last one. (details)
Member
us09
Re: FFT performance
Yep. I have the last one.
Active Participant
rpursley8
Re: FFT performance
It is part of the Advanced Signal Processing toolkit.
Randall Pursley
Active Participant
rpursley8
Re: FFT performance
Back to your original question.  It appears that the Mathscript interface is not optimized enough to match performing the same function outside Mathscript.  But, I'm sure in the next version of LabVIEW, this will be improved upon, but I'm guessing will never quite reach the same performance as calling the function directly outside of Mathscript.
Randall Pursley
Member
us09
Re: FFT performance
Thanks a lot for the information. I know that interfaces can be quite a
problem for data exchange. So I am looking forward to the next version
of MathScript :smileyhappy:.
Ulf Seidel
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
