LabVIEW MathScript RT Module
FFT performance
You can find the TSA Welch.vi under
Signal Processing | Time Series Analysis  | Correlation and Spectral Analysis.
It comes with the "Full Developers Suite".
Message 11 of 17
(5,703 Views)
Well, I have LabVIEW professional and don't have it.
I believe these tools are part of the NI LabVIEW Advanced Signal Processing Toolkit which costs extra. 😞
Message 12 of 17
(5,700 Views)
OK, you are mixing terms here, don't use "Full" in this context. 😉
There is "Base", "Full", "Professional", and "NI Developer Suite". You must have the last one. (details)
Message 13 of 17
(5,697 Views)
Yep. I have the last one.
Message 14 of 17
(5,686 Views)
It is part of the Advanced Signal Processing toolkit.
Randall Pursley
Message 15 of 17
(5,674 Views)
Accepted by us09
Back to your original question.  It appears that the Mathscript interface is not optimized enough to match performing the same function outside Mathscript.  But, I'm sure in the next version of LabVIEW, this will be improved upon, but I'm guessing will never quite reach the same performance as calling the function directly outside of Mathscript.
Randall Pursley
Message 16 of 17
(5,668 Views)
Thanks a lot for the information. I know that interfaces can be quite a
problem for data exchange. So I am looking forward to the next version
of MathScript Smiley Happy.
Ulf Seidel
Message 17 of 17
(5,661 Views)
