09-12-2014 10:52 AM - edited 09-12-2014 10:53 AM
Hi
I want to declare an empty 1D array in MathScriptRT node.
This code give a 2D array.
a = [];
I know in Matlab the above code will give me an empty 1D array.
Could anyone tell me how to declare it?
I am using LabVIEW 2013sp1.
Solved! Go to Solution.
09-12-2014 11:04 AM
I found a solution
a = zeros(1, 0);
But I am not happy with it. I need a simpler way.
09-12-2014 11:07 AM
A simpler way would be not to use mathscript at all and simply use an empty 1D array diagram constant. 😄
09-18-2014 06:55 AM
It does not like what NI advertised that most of basic MATLAB code can run on MathScript.
09-18-2014 09:21 AM - edited 09-18-2014 09:23 AM
What is "it"?
Maybe you are mistaken in your assumption? Looking at the matlab help,
a = [];
will create a 0x0 array, which is by definition 2D, right? A matrix of zero columns and zero rows!
09-24-2014 06:43 PM
HI altenbach
I was mistaken. I did not check carefully. a = [] will create 0x0 matrix.
Thank you
