01-24-2013 01:44 PM
Currently working with several different versions of Matlab on my workstation, and have not been able to figure out how to select the version that is opened when I run a Matlab Script. It always defaults to the same version. Haven't seen an existing thread that discusses this issue. Any ideas how to point the script server to a specific version of Matlab? Thanks.
GSinMN
Solved! Go to Solution.
01-25-2013 11:44 AM - edited 01-25-2013 11:45 AM
Hello GSinMN,
LabVIEW determines which version of the The Mathworks, Inc. MATLAB® to run by checking the registry for the MATLAB® Class ID and invokes that ActiveX object.
The KnowledgeBase article How Does LabVIEW Determine What Version of The MathWorks, Inc. MATLAB® to Use? describes how you can modify this registery entry to alter which version of MATLAB® the script calls into.
MATLAB® is a registered trademark of The MathWorks, Inc.
David A
