LabVIEW MathScript RT Module
Choose from multiple versions of Matlab
Currently working with several different versions of Matlab on my workstation, and have not been able to figure out how to select the version that is opened when I run a Matlab Script.  It always defaults to the same version.  Haven't seen an existing thread that discusses this issue.  Any ideas how to point the script server to a specific version of Matlab?    Thanks.
GSinMN
(7,143 Views)
Accepted by GSinMN
Hello GSinMN,
LabVIEW determines which version of the The Mathworks, Inc. MATLAB® to run by checking the registry for the MATLAB® Class ID and invokes that ActiveX object.
The KnowledgeBase article How Does LabVIEW Determine What Version of The MathWorks, Inc. MATLAB® to Use? describes how you can modify this registery entry to alter which version of MATLAB® the script calls into.
MATLAB® is a registered trademark of The MathWorks, Inc.
David A
(7,124 Views)
