03-06-2007 05:35 AM
03-07-2007 08:24 AM
04-22-2013 08:45 AM
I have the exact same question.
Now, several years later: Is it possible with the 2012 version?
Would it be possible if I use a *.m file, which I connect via a MATLAB (R) script node? (I have a licensed version installed)
Thanks!
Keks
04-22-2013 12:44 PM
Ohrkeks wrote:Now, several years later: Is it possible with the 2012 version?
Well, mathscript is now called Matscript RT and realtime targets are supported. (See also).
Ohrkeks wrote:Would it be possible if I use a *.m file, which I connect via a MATLAB (R) script node? (I have a licensed version installed)
What is "it"? Are you trying to run a matlab script node on RT? I think that only works on windows, not RT.
04-23-2013 03:12 AM
Thank you! 🙂
