LabVIEW Interface for Arduino Discussions
Reading SPI of MAX31855
I have it sending data now. I had to chenge retval to max_retval in the print statement
** MAX31855 Cold-Junction Compensated Thermocouple-to-Digital Converter
          case 0xFD:  // Init
                    MAX31855_Init(command[2], command[3], command[4]);
                    Serial.write('0');
                    break;
          case 0xFE:  // Read Raw Data
                    // Read raw data here.
                    max_retVal = MAX31855_readData();
                    Serial.write( (max_retVal >> 24) );
                    Serial.write( (max_retVal >> 16 & 0xFF) );
                    Serial.write( (max_retVal >> 8 & 0xFF) );
                    Serial.write( (max_retVal & 0xFF) );
                    break;
Also it reads on the hi to low transition so I fixed that in the code as well.
// MAX31855 Functions
void MAX31855_Init(unsigned char SO, unsigned char CS, unsigned char SCK)
          max_so = SO;
          max_cs = CS;
          max_sck = SCK;
          // MAX31855 data output pin
          pinMode(max_so, INPUT);
          // MAX31855 chip select input pin
          pinMode(max_cs, OUTPUT);
          // MAX31855 clock input pin
          pinMode(max_sck, OUTPUT);
          // Default output pins state
          digitalWrite(max_cs, HIGH);
          digitalWrite(max_sck, HIGH);
unsigned long MAX31855_readData()
          int bitCount;
          unsigned long data;
          // Clear data
          data = 0;
          // Select the MAX31855 chip
          digitalWrite(max_cs, LOW);
          // Shift in 32-bit of data
          for (bitCount = 31; bitCount >= 0; bitCount--)
                    digitalWrite(max_sck, LOW);
                    // If data bit is high
                    if (digitalRead(max_so))
                              // Need to type cast data type to unsigned long, else compiler will
                              // truncate to 16-bit
                              data |= ((unsigned long)1 << bitCount);
          // Deselect MAX31855 chip
          return(data);
Message 21 of 130
(7,702 Views)
ug this took a while to figure out... but it works now
Message 22 of 130
(7,702 Views)
ok i've been tinkering a bit have a look at this I'm working on the error bits next
Message 23 of 130
(7,702 Views)
Why didn't you use my VIs?  They should work with your fixed version of the firmware.  It's much much simpler.
The max_retVal was my fault but the second thing you mention surprises me because I took it directly from the library.  I'll update the library later tonight.
Message 24 of 130
(7,702 Views)
if you look i need to reorginize the bytes middle two for temp outside two for cjc
Message 25 of 130
(7,702 Views)
In the library, I have one for the thermocouple temperature already.  I will create VIs for everything else shortly but didn't have the time (at the time) and would like to get the critical parts tested and working.
Message 26 of 130
(7,702 Views)
Accepted by topic author LeXLuther422
With this setup it is doing everything even the errors
Message 27 of 130
(7,702 Views)
This is what I ended up making my display look like
Message 28 of 130
(7,702 Views)
Please excuse that my feedback took a whole day, but it was only now that I had to build the actual circuit arround the MAX31855, and than checked everything twice and threefold to make sure that the reson for your program always returning 0°C was somewhere in the code, and not in my circuit - so that I don't "blame" your program by mistake; that would be paltry.
I'm afraid my contribution isn't nearly as profound as LexLuther's: there are no "errors" in the example VI, but it just reads in 0s...
I don't know how to help you any better - just tell me, please.
Thanks again for the great help!
Message 29 of 130
(7,702 Views)
this is the base file I used and the vi's I used are available above in another post of mine.
EDIT: let me know if you want my latest vi with the display as picturd above.
Message 30 of 130
(7,702 Views)
