LabVIEW Interface for Arduino Discussions
Problem for connecting Arduino uno to Labview
1) I have installed 'Maker Hub toolbox' and then also installed 'Digilent LINX' from VI Package Manager to connect Arduino Uno. But I have to add two files all the time when I try to connect Arduino.
2) Another problem occurs when I open LINX wizard. In upload type selection, the folder is not generated when Build with Arduino IDE is chosen. Hence some Labview programs won't run properly.
How can I eliminate these errors?
(4,144 Views)
For questions regarding LINX, you should post on the official LINX support forums: http://www.labviewmakerhub.com/linx
In the meantime, you might try uninstalling LINX and the toolbox and re-installing.  Make sure that you restart LabVIEW after each step.
(4,077 Views)
oK. I will try it.
(4,063 Views)
hi ...what happen with your problem is solved? I have the same thing I do't now which option i choose of upload type for Arduino uno ...if you now tell me, please thanks.
(3,537 Views)
