06-02-2014 04:22 AM
hello...
can anyone help me, how to make overheat indicator lamp ??
01-28-2015 09:24 PM
I am also working on a similar project which requires me to display the temperature and humidity values from the DHT22 sensor on LabVIEW. I came across this post and I downloaded the attachment you had. I am new to LabVIEW so please bear with me. In the folder that I downloaded, I see a CustomFirmware, a .lvlib file and a .vi file. So correct me if I am wrong, but I have to load the CustomFirmware onto the Arduino, as I would have done before. Now do I have to replace the firmware from the following directory C:\Program Files (x86)\National Instruments\LabVIEW 2013\vi.lib\LabVIEW Interface for Arduino\Firmware\LIFA_Base with the custom one of just load it from wherever it is stored on my computer. Also do I have to copy the .lvlib and .vi file to some specific directory before I can use it. i would appreciate some clearance on the what I need to do with these files, or do i just open them up and use them.
01-28-2015 09:33 PM
If it was provided by me, you should be able to open the provided firmware in the Arduino IDE and upload it. The LabVIEW VI's should be able to be used from anywhere (but I'd recommend putting them in a logical place) since they only use functions that come with LIFA already.
01-29-2015 07:05 AM
Hi Nathan,
Thanks for responding. Yes, the files were provided by you. Can you give me an example of what would be a "logical place" for putting the VI's and what about the LabVIEW Library file (that is the .lvlib file), what do I do with this?
01-30-2015 12:07 AM
You can put the files anywhere you want that seems logical to you. I would put the whole folder provided in the zip file with your project (your VI) which uses that sensor.
02-10-2015 01:22 PM
Hallo, wie bekommen ich die Bibliotek für den Sensor DHT11 ins LabVIEW eingebunden. Ich habe Ihre Datei runtergeladen und habe es in Arduino abgespielt, ich bekomme eine Fehlermeldung. Ich brauche Ihre Hilfe. Ich möchte den Sensor über LabVIEW Programm auslesen. Vielen Dank für Ihre Hilfe
02-16-2015 02:57 PM
Hi Nathan, I am getting this error when I try to upload your LIFA into an Arduino Uno board.
Arduino: 1.6.0 (Windows 7), Board: "Arduino Uno"
Build options changed, rebuilding all
Using library Wire in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire
Using library SPI in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI
Using library Servo in folder: C:\Program Files (x86)\Arduino\libraries\Servo
Using library LiquidCrystal in folder: C:\Program Files (x86)\Arduino\libraries\LiquidCrystal
Using library Robot IR Remote in folder: C:\Program Files (x86)\Arduino\libraries\RobotIRremote
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10600 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI -IC:\Program Files (x86)\Arduino\libraries\Servo\src -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\libraries\RobotIRremote\src C:\Users\T!B!\AppData\Local\Temp\build5513844763982871198.tmp\AccelStepper.cpp -o C:\Users\T!B!\AppData\Local\Temp\build5513844763982871198.tmp\AccelStepper.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10600 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI -IC:\Program Files (x86)\Arduino\libraries\Servo\src -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\libraries\RobotIRremote\src C:\Users\T!B!\AppData\Local\Temp\build5513844763982871198.tmp\AFMotor.cpp -o C:\Users\T!B!\AppData\Local\Temp\build5513844763982871198.tmp\AFMotor.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10600 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI -IC:\Program Files (x86)\Arduino\libraries\Servo\src -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\libraries\RobotIRremote\src C:\Users\T!B!\AppData\Local\Temp\build5513844763982871198.tmp\DHT.cpp -o C:\Users\T!B!\AppData\Local\Temp\build5513844763982871198.tmp\DHT.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10600 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI -IC:\Program Files (x86)\Arduino\libraries\Servo\src -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\libraries\RobotIRremote\src C:\Users\T!B!\AppData\Local\Temp\build5513844763982871198.tmp\IRremote.cpp -o C:\Users\T!B!\AppData\Local\Temp\build5513844763982871198.tmp\IRremote.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10600 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI -IC:\Program Files (x86)\Arduino\libraries\Servo\src -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\libraries\RobotIRremote\src C:\Users\T!B!\AppData\Local\Temp\build5513844763982871198.tmp\LIFA_Base.cpp -o C:\Users\T!B!\AppData\Local\Temp\build5513844763982871198.tmp\LIFA_Base.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10600 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI -IC:\Program Files (x86)\Arduino\libraries\Servo\src -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\libraries\RobotIRremote\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\utility C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\Wire.cpp -o C:\Users\T!B!\AppData\Local\Temp\build5513844763982871198.tmp\Wire\Wire.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-gcc -c -g -Os -w -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10600 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI -IC:\Program Files (x86)\Arduino\libraries\Servo\src -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\libraries\RobotIRremote\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\utility C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\utility\twi.c -o C:\Users\T!B!\AppData\Local\Temp\build5513844763982871198.tmp\Wire\utility\twi.c.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10600 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI -IC:\Program Files (x86)\Arduino\libraries\Servo\src -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\libraries\RobotIRremote\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\utility C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\SPI.cpp -o C:\Users\T!B!\AppData\Local\Temp\build5513844763982871198.tmp\SPI\SPI.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10600 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI -IC:\Program Files (x86)\Arduino\libraries\Servo\src -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\libraries\RobotIRremote\src C:\Program Files (x86)\Arduino\libraries\Servo\src\avr\Servo.cpp -o C:\Users\T!B!\AppData\Local\Temp\build5513844763982871198.tmp\Servo\avr\Servo.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10600 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI -IC:\Program Files (x86)\Arduino\libraries\Servo\src -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\libraries\RobotIRremote\src C:\Program Files (x86)\Arduino\libraries\Servo\src\sam\Servo.cpp -o C:\Users\T!B!\AppData\Local\Temp\build5513844763982871198.tmp\Servo\sam\Servo.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10600 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI -IC:\Program Files (x86)\Arduino\libraries\Servo\src -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\libraries\RobotIRremote\src C:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src\LiquidCrystal.cpp -o C:\Users\T!B!\AppData\Local\Temp\build5513844763982871198.tmp\LiquidCrystal\LiquidCrystal.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10600 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI -IC:\Program Files (x86)\Arduino\libraries\Servo\src -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\libraries\RobotIRremote\src C:\Program Files (x86)\Arduino\libraries\RobotIRremote\src\IRremote.cpp -o C:\Users\T!B!\AppData\Local\Temp\build5513844763982871198.tmp\Robot IR Remote\IRremote.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10600 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI -IC:\Program Files (x86)\Arduino\libraries\Servo\src -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\libraries\RobotIRremote\src C:\Program Files (x86)\Arduino\libraries\RobotIRremote\src\IRremoteTools.cpp -o C:\Users\T!B!\AppData\Local\Temp\build5513844763982871198.tmp\Robot IR Remote\IRremoteTools.cpp.o
C:\Program Files (x86)\Arduino\libraries\RobotIRremote\src\IRremoteTools.cpp:5:16: error: 'TKD2' was not declared in this scope
int RECV_PIN = TKD2; // the pin the IR receiver is connected to
Error compiling.
02-16-2015 05:47 PM
The error is very common and there are many posts regarding that error. LIFA is old and not recomended because it is not being updated or offically supported. LINX has replaced LIFA.
If I had to guess at what the solution was, it was probably that you can't use a current version of the Arduino IDE because they have changed things since LIFA was deprecated.
02-16-2015 06:34 PM
Thanks! Is there an easy hack?
02-16-2015 06:40 PM
I'd suggest searching the LIFA community for posts regarding this same error. I probably posted a potential solution at one point and you'll probably see replies confirming or denying it's useful ness.
