Home > Community > Discussion Forums
Do you mean
Announcements
We've turned on a search before post feature in the LabVIEW Idea Exchange. This new feature will help cut down on the number of duplicate ideas in this space!
The NI Idea Exchange is a product feedback forum where NI R&D and users work together to submit ideas, collaborate on their development, and vote for the ones they like best. View all of the NI Idea Exchanges to post an idea or add your opinion on an existing one today!
wiring/insert ... but also DELETE
Status: Completed
by Trusted Enthusiast Trusted Enthusiast on ‎03-01-2012 04:45 PM
hello,
there are a lot of functions with only one input and only one output.
In this case, it would be very useful and easy to also have the function "Delete".
Insert (very useful) .... but also "delete"
This would avoid having to delete it, have pieces of broken wiring on both sides,
remove the broken wiring .. and then rewire all.
It's not very user friendly, really.
Like this :
Status: Completed
Available in LabVIEW 2015 and later
Comments
‎03-01-2012 04:49 PM - edited ‎03-01-2012 04:50 PM
Yes, i know .. we have the keyboard shortcut "CTRL space + CTRL R" to do that,
but it would be much easier to have it directly in the menu, like "insert".
ouadji,
by Knight of NI Knight of NI
on ‎03-05-2012 10:34 AM
What should happen if the primitive has more inputs than outputs or if they are of different type?
When inserting, we can predict which input should be used by going slightly below or above the wire. Do you suggest a similar mechnism for "delete"?
In any case, the current "delete" functionality, (using the delete key, which breaks all wires) needs to be retained too, because that's what we sometimes need to do! To avoid confusion, your suggested new functionality should not be called "delete". How about "excise" or "remove"?
on ‎03-05-2012 03:40 PM
"remove" instead of "delete", yes it's a good idea.
"What should happen if the primitive has more inputs than outputs or if they are of different type?"
the same behavior as < ctrl_space + ctrl_r >
by Active Participant Silver_Shaper
on ‎03-15-2012 10:10 AM
Kudo's to altenbach
on ‎08-17-2015 04:56 PM
Status changed to: Completed
About LabVIEW Idea Exchange
Have a LabVIEW Idea?
  1. Browse by label or search in the LabVIEW Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea to the LabVIEW Idea Exchange. Be sure to submit a separate post for each idea.
  5. Give kudos to other ideas that you would like to see in a future version of LabVIEW!
Idea Statuses
Top Kudoed Authors
User Kudos Count
41
17
13
6
5
