hello,
there are a lot of functions with only one input and only one output.
In this case, it would be very useful and easy to also have the function "Delete".
Insert (very useful) .... but also "delete"
This would avoid having to delete it, have pieces of broken wiring on both sides,
remove the broken wiring .. and then rewire all.
It's not very user friendly, really.
Like this :
Yes, i know .. we have the keyboard shortcut "CTRL space + CTRL R" to do that,
but it would be much easier to have it directly in the menu, like "insert".
ouadji,
What should happen if the primitive has more inputs than outputs or if they are of different type?
When inserting, we can predict which input should be used by going slightly below or above the wire. Do you suggest a similar mechnism for "delete"?
In any case, the current "delete" functionality, (using the delete key, which breaks all wires) needs to be retained too, because that's what we sometimes need to do! To avoid confusion, your suggested new functionality should not be called "delete". How about "excise" or "remove"?
"remove" instead of "delete", yes it's a good idea.
"What should happen if the primitive has more inputs than outputs or if they are of different type?"
the same behavior as < ctrl_space + ctrl_r >
Kudo's to altenbach
You must be a registered user to add a comment here. If you've already registered, please log in. If you haven't registered yet, please register and log in.
Post New Idea to submit a product idea to the LabVIEW Idea Exchange. Be sure to submit a separate post for each idea.
My Profile | Privacy |
Legal |
Contact NI
© 2011 National Instruments Corporation. All rights reserved. | E-Mail this Page
E-Mail this Page
