Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
While creating a labVIEW vi directly from vision assistant, the buffer needs to be manually allocated.
I have faced this minor hitch of changing the palette to actually view the image when i am starting with a color image and ending with a binary image. Automatically allocating optimized buffer for image destination will save some time as well as avoid "Incompatible image type error". The problem will get multiplied when you have created a subvi and have used a "imaq extract function" before this. The buffer will automatically get overwritten. Hmmm I know this is a luxury but still.......................
