How about having a timeout occurrence as an input for functions which support timeouts?
I am illustrating a single use case with queues (and a notifier) but I would see this as being beneficial to nearly ALL functions with timeout inputs.
Sometimes we'd like to wait for one of a few different functions (an example of mine which springs to mind is the Dequeue primitive). At the moment we must essentially poll each primitive with a relatively short timeout, see if one responded and then handle accordingly. This is (for me at least) ugly to look at and introduces polling which I generally don't like. I'm an events man.
What I propose would be that instead of simply defining a timeout in milliseconds we can define both a timeout (in milliseconds AND an occurrence for the timeout). If we wire this data to several primitives (all sharing the same occurrence) the first primitive to receive data triggers the occurrence so that the others waiting in parallel return also.
In the case where no data arrives, each function waits the defined amount of time but upon timeout DOES NOT fire the occurrence. This would cover corner cases where you may want different parallel processes to have different timeouts (Yes there are cases although they may be rare). It is possible to change the "priorities" of the incoming queues in thie way.
Background info: One example where I could use this is for RT communication. Here we multiplex many different commands over TCP or UDP. On the API side it would be beneficial to be able to work with several strictly-typed queues to inject data into this communication pipe while still maintining maximum throughput. I don't like using variants or flattened strings to achieve this multiplexing.
Being forced to poll means the code must decide between efficiency (low CPU usage) OR response time (setting a very low timeout). Although the CPU load for polling may be low, it's not something I personally like implementing and I think it's generally to be avoided.
There IS a LVOOP solution to this particular problem but not everyone can use LVOOP in their projects (for various reasons). I can envisage other use cases where interrupting a timeout would be desireable (Event structure, wait on ms, VISA read and so on and so forth).
Shane.
