NI Home
Cart Cart | Help
You are here:
Announcements
The NI Idea Exchange is a product feedback forum where NI R&D and users work together to submit ideas, collaborate on their development, and vote for the ones they like best. View all of the NI Idea Exchanges to post an idea or add your opinion on an existing one today!
Technico
(sub)VI-Icon: make "Find All Instances" also available when VI is locked (Read-only)
Status: New
by Member Technico on ‎08-05-2009 07:11 AM
I always use "Find All Instances" for searching where a subvi / control is used.
When looking into code that is locked (read-only because of being under source control), this option is missing!!.
  • Now I always have to press Ctrl-M to Unlock, then press change on the next dialog
    before the "Find All Instances" becomes active
  • Or open the VI Hierarchy (could take a while on a large project)
    and here the normal right-click "Find All Instances" is not blocked!!
I don't think it should be a big problem to enable the right-click menu on a locked vi...
Comments
by Knight of NI on ‎08-05-2009 03:28 PM
This also happens with subVIs when the calling VI is running and the ideaapplies for that too.
by Member silmaril on ‎08-08-2009 04:57 AM
Not having the "Find All Instances" function on locked VIs is especially anoying if you are using Perforce, with the option "treat read-only VIs as locked" on (Perforce sets the read-only bit on every VI that's not checked out).
by Trusted Enthusiast on ‎02-12-2011 09:45 AM
The UI for the find results would need some reworking... we'd need to mark items in the results list that are locked to indicate that Replace won't work. The Replace All button would need to prompt for unlocking diagrams and/or some shortcut for users to only do the replace on diagrams that are already unlocked, maybe a 3rd button ("Replace All Unlocked") or some other UI element.
The above comments are not a pro or con of this idea... just noting something else that would have to be addressed as part of this idea.
Latest LabVIEW Idea Exchange Blog Posts
About LabVIEW Idea Exchange
Have a LabVIEW Idea?
  1. Browse by label or search in the LabVIEW Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea to the LabVIEW Idea Exchange. Be sure to submit a separate post for each idea.
  5. Give kudos to other ideas that you would like to see in a future version of LabVIEW!
Idea Statuses
Top Kudoed Authors
User Kudos Count
129
78
67
65
56
