About LabVIEW Idea Exchange
Have a LabVIEW Idea?
  1. Browse by label or search in the LabVIEW Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea to the LabVIEW Idea Exchange. Be sure to submit a separate post for each idea.
  5. Give kudos to other ideas that you would like to see in a future version of LabVIEW!
Top Kudoed Authors
"Build Path" should be growable
                                            "Build Path" should be Growable
                              something like this,
8 Comments
Trusted Enthusiast Trusted Enthusiast
Trusted Enthusiast
Here is another interesting  one , but mine is different.
My idea relates more specifically to the growable capability.
maybe combine both ?
Trusted Enthusiast
Trusted Enthusiast
If this did get implemented, the trailing slashes in your picture would not be needed, just like they aren't today in Build Path.
Trusted Enthusiast
@AristosQueue : "If this did get implemented, the trailing slashes in your picture would not be needed, just like they aren't today in Build Path."
indeed, You're right !
Knight of NI
Knight of NI
To expand on this idea: BuildPath should accept an array of strings (or paths) too…
Knight of NI Knight of NI
Knight of NI
It should probably be pointed out that LV already has a primitive called Array of Strings to Path, which does cover the basic functionality of this idea, although not with the same syntax.
Active Participant PhillipBrooks
If implemented, the companion Strip Path function should also allow be "growable".
Member Rob_F1
I like it, this wold be very useful and clean.
Knight of NI
I like it!  like autoindexing a path to string array both ways!  We have the ability to code the stuff nativily but, this is one where NI R&D might be able to add more "bullet-proofness" than the general population.
