About LabVIEW Idea Exchange
Have a LabVIEW Idea?
  1. Browse by label or search in the LabVIEW Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea to the LabVIEW Idea Exchange. Be sure to submit a separate post for each idea.
  5. Give kudos to other ideas that you would like to see in a future version of LabVIEW!
Top Kudoed Authors
merging string-constant with empty-string-constant (same for path)
As everybody knows there are two ways for generating an empty string constant in the block diagram: Using the "empty-string"-constant or creating a genereal string constant with no content.
Both ways have advantages and disadvantages:
- The "empty-string"-constant shows much better that the string is empty but it can't be used e.g. in arrays.
- The string-constant can always be used, it is easily generated by right-klick to a string terminal and selecting "create -> constant". Furthermore its value can be changed to somthing non-empty if required. Disadvantage: It's hard to see if the constant contains nothing or just a blank sign.
My suggestion: LabVIEW shall show a string constant which contains an empty string always with the symbol that is currently used for the "empty string"-constant. This is also valid if the empty string is within an array or cluster. If this behaviour is not wanted in a particular case, there shall be the conext-menu-option "show symbol for empty string" which could be deactivated.
For changing the value of such a new string constant, the symbol shall change to a classic string constant if the user moves the mouse (with selected text-editing-tool) over it.
Similar behaviour is also suggested for general-path- / empty-path-constants.
Remark: I'm working with LV2015SP1
15 Comments
Intaris
N/A
Kudos for the idea, but maybe a bit less for the visuals provided.... Smiley Tongue
Proven Zealot
Proven Zealot
Personal opinion:
That's a really good idea. Kind of amazing no one has ever suggested it before to the best of my knowledge.
Kudos.
R&D opinion:
I'll pass it along to the team and see if anyone else is as enthused as I am.
crossrulz
N/A
I will give kudos to the idea of some indication that the string is empty.  I am not liking the "Empty String Constant" in the array.  Should be something a little less obnoxious.
X.
N/A
I don't see the point. If you are really afraid to insert a space instead of an empty string, just show the Display Style and choose '\' Code Display:
There is zero ambiguity as to what you are passing. We are talking about CONSTANTS right? How many empty string constant do you use in your diagrams, really?
IngoG
N/A
Kudos for the idea, but I go with crossrulez: No "empty string constant" in the array.
Andi_S
N/A
hey - I just moved some pixels on my screen-shot tool. Beautifying should be done by the designers from NI ;-)
Is this better?:
N/A
Hi Andi,
I'm with X: show the display style of the string constant and you are sure what's inside the string constant! I would even make the display mode indication visible by default
With your last image: you still don't know how many spaces/tabs/other non-printable chars are in your string constant! All you know is: it contains "something"…
Andi_S
N/A
You're right - but to see if a string is empty or not is much more than what you know currently can see (without changing the display style).
One more remark: I don't want to see the discussion too much in direction array or display style. The main intension for this idea was to remove this special "empty string constant" by transferring its good empty-string-visibilty to the standard string constant (in it's default view setting).
Andi_S
N/A
I'd like to extend my idea a little bit. If size to text is disabled it's not possible to see if a constant contains an empty string or a short string or a string which fills the visible field completely.  Why don't visualize the end of the string?
Mythilt
N/A
I have to say I like the basic idea.  Using the '\' mode can make the string hard to scan visually since it removes the natual breaks in the string, so you would catch that the one string is empty, but would be more likely to miss that another string has a mispelled word.  (The brain finds it easier to see the misspelling in 'It's thiers Susan.' than it does in 'It's\sthiers\sSusan.\n\r' its just how we are wired)  And I know that you can toggle '\' mode, but that adds multiple steps.
