User | Kudos |
4 | |
3 | |
2 | |
1 | |
1 |
I am not sure whether something similar has been propoesed or not..
This is something to do with the ICON EDITOR...I propose a "ICON Manager" (see Endevo ICON Manager) with which it should be possible to apply the icon to all the vi's/ctl present in the directory or llb.
-->The Name of the folder or the first name of the vi (ex: If the subvi name is "abc_xyz.vi", then "abc" will be the header and "xyz" would be the body) can be used as the header. (or automatically find the header)
-->An option to preview and apply the same to all the vi in the directory (whether they are linked to one another or called dynamically should not matter)
-->An option to select the Main (toplevel) vi and apply the icons to all the calles
Any idea that has received less than 5 kudos within 5 years after posting will be automatically declined.
