About LabVIEW Idea Exchange
Have a LabVIEW Idea?
  1. Browse by label or search in the LabVIEW Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea to the LabVIEW Idea Exchange. Be sure to submit a separate post for each idea.
  5. Give kudos to other ideas that you would like to see in a future version of LabVIEW!
Top Kudoed Authors
give decorations a label property to address and modify them programatically
Remark: I'm using LV2015SP1 - maybe there is already a change in LV2016.
Sometimes it's very useful to modify a front-panel decoration element programatically. E.g. moving it, changing its size, color or visability. All of those properties do already exist.
Because a decoration element does not have a property node, it must be searched via the decorations-property of the pane. The problem here is, that there no possibility identify a particular decorcation element because there seems not to be any identifier property.
What I'm requesting to resolve this awkward situation is to give all decoration elements a label-text property (or any other identifier property) which can be set during programing time by the LabVIEW programmer.
5 Comments
Member Mythilt
I actually would not mind this, there have been a few times I've wanted to do things like change a decorations color programatically, but trying to determine which decoration is which was too much a pain.
Active Participant Kyle97330
If you enable VI scripting (Tools->Options->Vi Server->Vis Scripting->Show VI scripting functions, properties and methods) there's a "UID" property node that you can access.  It's a number, but once you get it from a decoration it won't change on that VI.
Member Andi_S
Thank you :-) ... I already found this before I wrote my idea ... but for a "normal" programmer or beginner its too good hidden and much too complicated to use. So I wrote this label thing. Whereby I personally prefere the other idea where I can create a property node which is directly linked to a decoration.
Interesting by the way: There is already a label field in the property dialog of a decoration but it is disabled and greyed.
Active Participant Manzolli Active Participant
A label can be useful in a decoration,not only to identify it in the BD. Kudos!
Trusted Enthusiast
Trusted Enthusiast
This idea is already discussed in this one: Improved decoration and control graphics
but is one among other suggestions.
As I mentioned in my comment to your other related suggestion (also a duplicate), this is something that NI hasn't included in its Next Generation LabVIEW Preview, despite it being mainly focused on UI and changes to FP and BD graphics.
<OOT> Now, to be fair (!), there isn't ANY property nodes to be seen in this preview, which makes it something like a vintage version of LabVIEW of sort.
But this suggestion of yours made me take another look at the Preview (which I have given up playing with, so limited it is) and here is the shocker:
THERE ISN'T ANY CAPTION either!
At least not that I could find. So objects other than decorations have a label (it is called a "name"), but that's it. And of course, since there is not property node (yet), it doesn't really matter that much... </OOT>
