User | Kudos |
4 | |
3 | |
3 | |
2 | |
2 |
Although new folders can be created in the application and installer build specifications, they are not created unless a file is put there. An empty folder is desireable for data output. It would be better for it to be created before running the application so that security access rights can be set by the person doing the installation if administration priveleges would otherwise be needed to create new files there. It leaves quite a bad impression on those who waste time finding out by trial and error that the folders defined in the build specifications are not created. The forum also documents complex schemes to work around this limitation by people who surely would rather have been doing something productive instead.
