When you want to save a XControl, you have to save 5 items ... the savefiledialog appears 5 times ...
The problem is, that when you add an XControl to an autopopulating project, the savefiledialog appears 5 times,
without any memory of the last path used ! You have to browse 5 times save all elements.
Here some possible solutions to this problem ...
- The save file dialog should keep the last saving path in memory
- In autopopulating project, the saving path should be automaticaly taken from the project architecture
- A special save file dialog could be build, enabling to rename and save all 5 elements in the same directory ( This solution force to save the file in the same path ... is it good ? for me i think so ! )
Manu.net
Any idea that has received less than 7 kudos within 7 years after posting will be automatically declined.
