Programming issue. Pushed to NI Forums for resolution.
Will be good when running an application in debug, keep other LabView project enable and editable, so I can continuous to work under other project waiting the debug stop at break point
Even if you run a VI in one project, you should still be able to edit the second project (assuming that your VIs aren't modal and blocking the entire LV process).
I believe you should even be able to edit VIs which are shared between the projects, because LV loads a copy into memory for each application instance, but that would have to be verified.
