NI Home
Cart Cart | Help
You are here:
Announcements
The NI Idea Exchange is a product feedback forum where NI R&D and users work together to submit ideas, collaborate on their development, and vote for the ones they like best. View all of the NI Idea Exchanges to post an idea or add your opinion on an existing one today!
CFiset
When debugging a LabView apps, keep other LabView Project editable
Status: Declined
by Member CFiset on ‎09-21-2010 08:02 AM
Will be good when running an application in debug, keep other LabView project enable and editable, so I can continuous to work under other project waiting the debug stop at break point
Status: Declined
Programming issue. Pushed to NI Forums for resolution.
Comments
by Trusted Enthusiast on ‎09-21-2010 11:29 AM
What is actually happening?
You should be able to have 2 projects open. In one project you acces the 'remote application'.
Ton
by Member CFiset on ‎09-21-2010 11:45 AM
This is a way to do. I like to run a non compiled VI in a project and in same time working under a other project
by Knight of NI on ‎09-21-2010 06:54 PM
Even if you run a VI in one project, you should still be able to edit the second project (assuming that your VIs aren't modal and blocking the entire LV process).
I believe you should even be able to edit VIs which are shared between the projects, because LV loads a copy into memory for each application instance, but that would have to be verified.
Are you saying that this is not working for you?
by Active Participant G-Money on ‎02-08-2011 06:06 PM
This shouldn't be an issue. If you are running into this issue, please post to ni.com/forums so we can find out what's going wrong for you.
by Active Participant G-Money on ‎02-08-2011 06:07 PM
Status changed to: Declined
Latest LabVIEW Idea Exchange Blog Posts
About LabVIEW Idea Exchange
Have a LabVIEW Idea?
  1. Browse by label or search in the LabVIEW Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea to the LabVIEW Idea Exchange. Be sure to submit a separate post for each idea.
  5. Give kudos to other ideas that you would like to see in a future version of LabVIEW!
Idea Statuses
Top Kudoed Authors
User Kudos Count
131
82
66
65
61
