About LabVIEW Idea Exchange
Have a LabVIEW Idea?
  1. Browse by label or search in the LabVIEW Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea to the LabVIEW Idea Exchange. Be sure to submit a separate post for each idea.
  5. Give kudos to other ideas that you would like to see in a future version of LabVIEW!
Top Kudoed Authors
Variable Speed highlight execute
Title says it all. Have a slider or pull-down that increases or decreases the highlight execute rate.
14 Comments
Member simplemaan
I'm not sure about rewinding, etc, but I've really wanted the execution highlighting variable speed slider.
There are ways to get around slow bubbles by using breakpoints efficiently to skip ahead, but one situation has me really wanting a variable execution speed: if you are watching a loop progress and you know that your issue doesn't occur until after several loop iterations.
You can set a breakpoint on an object inside the loop, but then you have to click through every iteration, which could get old very quick.  Maybe add code to test the iteration count and trigger a case structure with a breakpoint inside of it, I don't know, but it would be nice to be able to just move the slider to "faster", let the loop progress for a while, then move it back to "slower" and check on it again.
Let me also point out that there is a feature similar to this in TestStand that has a slider on it to speed up or slow down test routine execution speed.
Knight of NI Knight of NI
Knight of NI
As I mentioned in the other thread, you can handle this today with a conditional probe.
Proven Zealot
Proven Zealot
Since this thread popped up again, it reminded me that I wanted to post a possible UI that I was thinking I'd like. (Note: I'm not actually working on this feature. This post is from me as a LV user, not me as a LV developer.)
Member Jaysha_18
I want this option in LabVIEW. Many times I want to run some section with high speed and some really slow.
This idea sounds really nice.
