I'm not sure about rewinding, etc, but I've really wanted the execution highlighting variable speed slider.
There are ways to get around slow bubbles by using breakpoints efficiently to skip ahead, but one situation has me really wanting a variable execution speed: if you are watching a loop progress and you know that your issue doesn't occur until after several loop iterations.
You can set a breakpoint on an object inside the loop, but then you have to click through every iteration, which could get old very quick. Maybe add code to test the iteration count and trigger a case structure with a breakpoint inside of it, I don't know, but it would be nice to be able to just move the slider to "faster", let the loop progress for a while, then move it back to "slower" and check on it again.
Let me also point out that there is a feature similar to this in TestStand that has a slider on it to speed up or slow down test routine execution speed.
As I mentioned in the other thread, you can handle this today with a conditional probe.
Since this thread popped up again, it reminded me that I wanted to post a possible UI that I was thinking I'd like. (Note: I'm not actually working on this feature. This post is from me as a LV user, not me as a LV developer.)
You must be a registered user to add a comment here. If you've already registered, please log in. If you haven't registered yet, please register and log in.
Post New Idea to submit a product idea to the LabVIEW Idea Exchange. Be sure to submit a separate post for each idea.
My Profile | Privacy |
Legal |
Contact NI
© 2011 National Instruments Corporation. All rights reserved. | E-Mail this Page
E-Mail this Page
