User | Kudos |
18 | |
17 | |
10 | |
5 | |
3 |
By using the VI-server reference "pane" > you will obtain a array which contains a reference for each used element. This VI-server reference can be wired in any sub-VI, to check for example the state (value) of a element. Into the respective sub-VI the array function "Array Index" can be used to check the value of the element. Everything will work fine, until you put another element into your frontpanel. At this point, LabView change the order of the reference array. Now the user wish to have a function, to edit the reference number of each element (like "Change order of elements in cluster"). The problem remains, even if the new element will be deleted.
Any idea that has received less than 2 kudos within 2 years after posting will be automatically declined.
